water feature really important
hey does anyone know how to make a curved water feature easily?? i tried doing a slan and then changing its texture but i can't add the textures from the website http://www.archibaseplanet.com/download/2622.html to archicad, so pls if anyone has a solution to that tell me, because i need to download other textures for my elevation as well,
thank you so much i really appreciate your help...
6 REPLIES 6
Dwight
What is a curved water feature?
How long is string?
Make a sketch.
Dwight Atkinson
i'am sorry with curved i meant with curved edges, i want to do something like the picture attached with some gravel for example around its edges,
i also need to create a simple waterfall that starts at the first floor and end at the waterfeature,
thank you for your help....
undefined
this is another figure of what i'am attempting to do..
undefined
Dwight
If you were to post your machine and software spec in your signature, I could advise you better.
You need a rock maker.
There is a small application that makes rocks called MacRock. I know many think this application is for music, but no.
As for water falling, investigate the complex profile used as a wall.
Uncle Eric's Complex Profile Tricks
Dwight Atkinson
Dwight
Followup:
MAcRock for MAc AND PC
Dwight Atkinson
thank you so much you were of great help and thanks also for the quick reply
