window/door associated "size" label
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2008-09-06
06:09 PM
2023-05-24
12:42 PM
Rubia Torres
Does someone know of associative object size (dimension) labels that work in plan and also show in elevation AC 12? I know it can do the id#s, but that’s not what I want.
Especially interested in Door and Window plan “label” (see image) (SIZE) being seen in PLAN & ELEVATION, only setting it ONCE.
A legend is ok as reference for more data, but floor plans/elevations being “size-taged” makes for a lot
less mistakes when visualizing, ordering and placing specialized and expensive items like doors and windows.
It may be simple by now (12), but I'm not getting it.
Even after also reading our wonderful manual?
If not stock way, location of “smart” label object that will do this, I can purchase?
Thanks
Bier
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-09-09 03:06 PM
ArchiCAD since 4.55 ... 1995
HP Omen
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-09-10 07:49 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-09-10 08:47 AM
Would you be so kind as to tell me where that is?
I have tried searching for that description, "Object label" and so far nothing has shown up. Is this a generic term, or is it a specific AC label that can be attached to doors and windows, for plan and elevation; and maybe other objects?
Obviously, labels are new to me.
Thanks
Bier
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-09-12 11:09 AM
Bier wrote:In an elevation, select all the windows, open the window settings, under Listing and Labeling check the Label objects box. You can do this from the Info box too.
Djordje, Thanks for your reply.
Thanks
Bier
Labels will appear on all the windows.
Then, select all labels, open label settings. The default label is text, the flyout on the upper right. Change to Object label. Close settings. Open them again, in the bottom is the Object label settings tab. Open it and set the parameters as you like (label shape, what is shown in the label, pens, text sizes - label outlines adjust to text size), click OK.
You should have all the windows labelled as you like. Save ther Favourite for the label, in order to re-use later.
HP Omen
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-09-13 06:16 AM
That's now got me on the path.
Looks like another big dimly lit "room" in
AC I need to explore.
Bier
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-09-16 07:43 PM
Bier wrote:Caverns, not rooms
Thanks again Djordje
Bier
HP Omen
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-12-10 06:07 PM
Shoegnome Architects
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-12-10 06:15 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-01-07 10:10 AM
2. Is it possible to make my label as a default in new project?
