Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
writing i/o scripts to read external data files
guess my programming skills are poor but trying to write a script to read an external x.y.z points file and convert to a 3D grid perhaps using planes. Anyone willing to share an example?
1 REPLY 1
Frank Beister
The problem will not be to import the points, but to calculate which are neighbours, which are in the same plane and resulting out of this, which built a valid polygon.
For importing external data you need to know, which datat format they will have, and where they do come from. (CSV, TXT, XML etc.)
