ArchiCAD 13 EDU available
ArchiCAD 13 EDU is available for some time now.
It can be downloaded from
https://myarchicad.com/
10 Replies 10
I created my account in MyArchiCAD, but at the moment I tried to download the educational version of ArchiCAD 13. The only option that I have is the Spanish version. ( I'm from LatinAmerica, Perú). I fell confortable with the INT version and I've been working since the ArchiCAD 11 and I dont want to change to the spanish version its a matter of costume. How can I donwload the ArchiCAD 13 EDU INT version?
Report such problems to the following email address:
myarchicad (at) graphisoft [dot] com
I sent an email a week ago an i get no response
I register Archicad 13 educational last year at December, and I downloaded it a few days ago. But when I finished to download I found that the expired had counted from the first day I registered it. So now I only have 5 days (My archicad 13 educational expired is 13-01-2010). Is there any solutions to solve this, like renewal the serial number ?
AnnaGraph
If your one-year serial number can be approved by your local partner, you can continue using your educational version.
Go to your profile page and find the partner detail at the bottom of the page. Contact them asking to approve your educational status.
Hi there, just wondering if anyone would be able to help!
I have downloaded the ArchiCAD 13 EDU version, I had intstalled it and everything, but it says I need something called 'TextEngine.dll' to run the programme.
So what's the 'TextEngine.dll' , Where can I find it and where should I have it in the computer?
That DLL should not be missing.
Something may have gone wrong with the installation.
Try to download the installer again and reinstall.
Make sure you do it as an administrator.
Umm... so I re-installed the ArchiCAD, and got that running But does this version comes with the Standard object library? coz mine one is missing and I can't work with that... So where can I find it for download?
The TextEngine.dll file is located in the ArchiCAD folder. It is not part of the Library.
The library should install along with the application.
Something must be wrong with your installation.
