Automatic License Update
License Activation
Starting with ARCHICAD 22, you can easily get your license activated/updated by starting an installed ARCHICAD 22, this way it gives you a more seamless experience with your license. When you  start ARCHICAD 22 after successful installation without signing into GRAPHISOFT ID, a dialogue window appears with different license options on how to start ARCHICAD:
  • If you have already acquired a Commercial license on Hardware or Software Key, select the second option.
  • Select Download Software Key.
  • ARCHICAD will download the license from the License pool after verifying your GRAPHISOFT ID (GSID) Information:
      • GRAPHISOFT ID dialogue window appears where you can enter existing credentials or sign-up for a new GRAPHISOFT ID.
    Downloading Protection Key
  • After successful authentication, ARCHICAD downloads automatically the available protection key from License Pool.
      Note: The license download may take a few minutes, please be patient.
Protection Key Download Successful
  • When the download is successfully completed, you should be able to use ARCHICAD in full mode afterwards.
