2024-03-19 05:31 AM
I made a mistake when choosing the version of Archicad I wanted, my current educational license is active with Archicad 27, but I need it with Archicad 26 due to hardware issues
Do you know if I can register on both?
2024-03-19 06:14 AM
I have been told that an EDU license for 27 will also run older versions.
I can't confirm 100% as I don't have an EDU license.
But try installing 26 and apply the 27 license to it.
I assume it must work because it is not possible to apply for a 26 license, you can only get 27 EDU license now.
2024-03-20 09:56 AM - edited 2024-03-20 10:22 AM
Hi Pablo,
If you're signing up for Myarchicad for the first time, you'll receive the license for the latest version available in the market. However, if you need to obtain a previous version, for instance, because your computer doesn't meet the minimum requirements, or your professor teaches you to use an older version, you can send an email to myarchicad@graphisoft.com specifying your request.
Do note that if you're not using Archicad 27, you won't be able to access the BimCloud Educational service.
Joe
Giovanni Logiudice
Educational Community Expert, Moderator
Certified GRAPHISOFT ARCHICAD BIM Manager2024-03-20 10:17 AM - edited 2024-03-20 10:19 AM
there's a typo in the mailaddress you mentioned:
myarchicad@GRAPHISOFT.com
edit: i didn't manage to remove the mention to the user graphisoft. sorry for that
