Licensing
About all sorts of licenses, their management, Graphisoft ID, Graphisoft Store, License Manager Tool, etc.
Cutting holes
Hi m a new user to archicad i m a civil engineer and make most of my plans in autocad.. now i m using archicad cause its very much time saver...
i want to know how can i cut holes in walls, slabs etc
rectangular, circular or of any shape....
4 REPLIES 4
Dwight
You'll really want to start with the Reference Manual and other documents found under the HELP menu including "Getting Started."
The USA version of the Reference Guide has slab holes on page 215.
Walls are cut with window openings - irregular window openings must be created as windows - this requires some study.
Dwight Atkinson
Dwight
See your window library for the FOLDER " Openings"
Dwight Atkinson
this is very helpful.
can you put a window on top of another window?
because i'm trying to create an inbuilt shelving system in a wall.
Thomas Holm
Try reading the manuaL Help menu!
