2023-07-06
12:23 PM
2024-07-09
03:25 PM
Aruzhan Ilaikova
I was getting in touch because once I was working on the educational version, I created a template (pens, vegetables, ovm, overlays, views, layouts, compositions, etc.) However I bought your annual license and wanted to start working on the commercial one but with the template I created previously in the EDU version, however it gives me error because they are different versions (one EDU and one educational) even though both are Archicad 26, is there a way to fix that?
2023-10-04 03:32 AM
I have received a multitude of engineering dwg files that are EDU watermarked over the years... though EDU ACAD is easier to aquire and lasts longer...
AC22-28 AUS 3110 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win11 | R5 2600 | 16GB | GTX1660 |
2 weeks ago
Does someone know if this exporting trick worked?
2 weeks ago
It will not, either they will not import indicating that the data comes from EDU or it will switch to EDU.
another Moderator
