vilmaferreira
File Conversion EDU to Comercial
I was getting in touch because once I was working on the educational version, I created a template (pens, vegetables, ovm, overlays, views, layouts, compositions, etc.) However I bought your annual license and wanted to start working on the commercial one but with the template I created previously in the EDU version, however it gives me error because they are different versions (one EDU and one educational) even though both are Archicad 26, is there a way to fix that?
12 Replies 12
Lingwisyer
Guru
I have received a multitude of engineering dwg files that are EDU watermarked over the years... though EDU ACAD is easier to aquire and lasts longer...
attiakiraly
Does someone know if this exporting trick worked?
Eduardo Rolon
It will not, either they will not import indicating that the data comes from EDU or it will switch to EDU.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
