filip8
INT to Czech
Hello,
I would like to ask how could i change the version of archcad from INT to czech. I have education version and I tried to apply for czech verison but it didn´t work.
I really don't know if this will work, but maybe worth a try.
You can download the Czech version from the Graphisoft website ...
https://graphisoft.com/resources-and-support/downloads?section=product&localization=CZE&product=arch...
Make sure you get the version and operating system to suits you.
Try to run it with your current INT license.
I believe with the commercial licenses, any language license can also run the INT language version (I have AUS and can also run INT and other English language versions, but not other foreign languages).
I am not sure if you have an INT license, if you can run other foreign language versions though, or only the other English ones.
I am less sure about the EDU licenses as I don't have one.
But if you don't mind downloading and installing the Czech version, it may be worth a try.
If it doesn't work, there should be a contact e-mail on the MyArchicad website.
Nurbs
As far as I know there is an option to change your prefered language version on MyArchicad.com
When you login to your account you may find some infos (FAQ) how to manage this.
AC16 - AC29, Rhino 5-8. Alienware WIN 11
