Lost Door, Window jamb/sill 2D drawing in Plan View
Hi
I have lost the Door/Window detail drawings in Plan View ... The door panel thickness is just a line and the Jambs for doors and windows do not show up in the Plan View.
I am using the US version but have changed the setting to get millimeters for international.
4 Replies 4
Thomas Holm
I'd guess you've either a changed the floor plan scale to something smaller (like 1:50 ->1:100), or changed the display settings from Cut or Projected to Symbolic.
Yes, sounds like scale-sensitive option is on in the door settings.
You guys are SUPER
Ebbie! Were your doors and jambs displaying as "detailed" i.e., with the door thickness and jambs previously???? And then one day they became lines? And you did not change the drawing's scale?
I would be very interested to find out if this has happened to you. My office has experienced this sort of thing very recently, and I'm trying to sniff out whether it's worth sending off to Hungary....
What has happened, as far as I can tell, is that at some time the door parameters got changed from "Detailed" to "Scale sensitive" seemingly by itself.
please let me know!
Zoll
And oh yes, Stuart and Thomas Holm are super!
