Requirements of the License Activation Website
Requirements of the site
To use the upgrade site, you will need:
  • A key that is eligible for upgrade and is connected to the computer.
  • An active Internet connection.
  • Installed protection key driver :WibuKey or CodeMeter based on the type of key you have.
  • A supported Internet browser (Safari, Internet Explorer).
  • Up-to-date Java environment (you can find detailed instructions below, how to install Java).
  • Enabled Java content in the browser
How to install, uninstall Java
If you are experiencing problems with the site on a PC, please follow these steps:
  • In Control Panel / Add-Remove programs check what Java versions are installed on your computer. There could be several different versions and upgrades installed.
  • Remove all Java versions and upgrades. Leave no Java component at all. Before doing this, make sure no other applications are using Java.
  • Reboot your computer (don't skip this step!)
  • Install latest Java from: Java.com
