Rotating item in library.
Hey, i am currently using ArchiCAD 12. I am using a Phillipe Starck bar tool in my design and as it is not in my library i am creating it.
At the moment i'm using the Elbow pipe in basic shapes. I was wondering if anyone knows how to get a different start point for the elbow as the point always starts at 90 degrees.
I moved the y axis to make it stand vertical but now i need to move it round into a different position.
My Angle of Bending is at 245
Y Axis 90
Any help would be appreciated.
6 Replies 6
David Maudlin
Kawsome:
If you can post an image of what you are trying to achieve, then you may get some different approaches to the solution (they may or may not include using the Elbow object).
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thomas Holm
Ah the Bar Tool - I can't find in my Work Environment -is it downloadable?
http://www.panik-design.com/acatalog/b-driade-sarapis-t.jpg
This is the bar stool i'm trying to create.
*Thomas* Its an object in the library, Basic Shapes.
David Maudlin
Kawsome:
These settings seem close. Note: the object preview is set to elevation.
HTH
David
That is awesome!
Cheers, you've been a great help.
vistasp
Mentor
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
