Title Type
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2008-07-25
08:38 PM
2023-05-25
06:13 PM
Rubia Torres
2008-07-25
08:38 PM
Or do I need to make a completely new title type...
I've edited everything else to make the title type look better but the line weights don't look right the same.
5 REPLIES 5
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-07-25 09:48 PM
2008-07-25
09:48 PM
Version of ArchiCAD, and name of the title type you're talking about please?
Titles have changed to GDL objects since they were introduced, so your version info is important... as is the title object info.
Thanks,
Thanks,
AC 28 USA and earlier • macOS Sequoia 15.4, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-07-25 09:50 PM
2008-07-25
09:50 PM
Griffin:
If the Title is using the 2D Script to generate the title, then you can use the Pen command to set the pen for each element. Is this an ArchiCAD Title, or one you created? The assigned pen number will have a line weight based on the setting in the Pens and Colors table.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-07-25 10:00 PM
2008-07-25
10:00 PM
I'm just editing the basic title type that it came with...I'm using Archicad 11 but updating to 12 in a few minutes.
I will add a profile but I was going to wait to do that till after I'm off work.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-07-26 12:04 AM
2008-07-26
12:04 AM
Still looking through the editor, but so far I've only found, with the editor and script, only the ability to edit the line-weight of both the circle and the line together, not separate. Either I'm just missing where it's at in front of me or I need to learn GDL editing better (probably both).
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-07-26 12:28 AM
2008-07-26
12:28 AM
'basic title type' is not the name of any title delivered with 11... I, and others, would help if you were more specific. 😉
