installation of network license version
Hi all,
I had a problem on installing ArchiCAD9 network license version.
The procedure i had followed is:
1.Installing the software in all the machines.
2.Installing network license Cd in all the machines.
3.Inserting wibu key in server machine.
4.lanching network serve from start menu>programs>wibu
key>network serve.
After completing all these steps when i lanch AC9 it was giving a warning box, WIBU KEY WAS NOT FOUND (128) RUN IN DEMO MODE OR QUIT.
can i know what r the extra precautions should i take.
Regards,
Rajesh.
Ben Odonnell
Rajesh,
This step is not necessary . The network licensing CD contains the WIBU-KEY Runtime Kit, which is server side only software. I don't think you will need to uninstall it though.
What you need to do on your clients is the following. You don't say which OS you have so I'll assume you are on Windows machines.
1. Go to your control panel and find the WIBU applet. If you are running XP and are using the "category view" in your control panel, you will find it under "Other Control Panel Options" on the left hand side.
2. Once you find the WIBU applet, choose the "Contents" tab, you will be taken there by default.
3. Double click on the Network icon, Double clicking on the icon will do a scan of your network to find available WIBU boxes.
4. If this yield nothing choose the "Network" tab. Then, under the "WKLan Server search list", key in either the name of the server or the ip address of the server on which the WIBU key is attached to, or you can even hit the browse button, doing a browse does not always yield results, that's why I suggest you key in the name or IP address.
5. Once you have done this go back to the "Contents" tab rescan your network ports, it should now find the WIBU box on your sever.
Note: If all fails I suggest that you uninstall the Server software that you installed on all of the clients and then try again.
HTH.
Cheers.
Ben
Ben O'Donnell
Architect and CTO at BIMobject®
Get your BIM objects from bimobject.com
