If you are using the EDU version you cannot (and should not by license agreement) share info with the "Pro" version.
The question is if you are using Modules for your EDU projects and if the AC (EDU version) cannot read them because the extension is MDE instead of MOD. If this is the case then, besides that being a BUG of the EDU Version, you should use regular PLN's as Module files instead. With this you should be able to keep everything working smoothly.
I don't have my EDU version installed right now so I cannot verify that I am correct.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08Macbook Pro M1 Max 64GB ram, OS X 10.XX latest
another Moderator
