Licensing
About all sorts of licenses, their management, Graphisoft ID, Graphisoft Store, License Manager Tool, etc.
printing problems in AC11 EDU
Hi!
Today I replaced my ArchiCAD10 EDU with the AC11 EDU and everythind looked to run well until I tried to print a simple drawing on A4 format on my home printer - the quality is very poor! Also when I try to print it in black and white it's a total disaster - there is no differenciation in gray scale!
I didn't have any problem with the AC10 version with the same file. I hope you'll give me an eplanation and a tip how to solve this problem because I already uninstalled the AC10 version and I don't want to return to it.
Thanks!
Marko wrote:
Hi!
Thanks!
Dear Marko
are you using the layout book ? or just printing at the model view?
did you try to publish to PDF ?
I don't use layout book, I just print it with marquee tool selection. It worked perfectly in AC10.
I tried to print in PDF but the resukt is the same. I put an attachment so that you can see the problem. Very simple-there is not gray scale colors in the black&white mode.
And when I print in color the quality is very poor..
