problems making a viaduct
hi there, iam trying to make a brick viaduct that is perforated by large brick arches. Ive tried making holes in the mesh but cant make horizontal perforations in the structure-is there a better way of doing this, either constructing it as a beam or wall with holes it it. Any help will be brilliant, thanks
Not enough information to answer without lots of speculation.
Can you post a picture of what you're trying to do? Is the slope of the viaduct sufficient that it is discernable? Curved route? Base/side construction, etc...
Karl
Dwight
This looks like a job for Complex Profile. YOu'd make the viaduct section and extrude it using the wall tool, or the beam tool if inclined. Arched window openings would be your penetrations.
Dwight Atkinson
