problem with training guide
Hello,
...i downloaded archicad educational version (teamwork) for mac from graphisofts website, i also downloaded the huge tutorial (just dl'ed it a couple days ago). all the video's work fine, but when i try to open the project files i get:
No data is allowed between educational and commercial projects. To perform this operation, you should first convert the commercial-version file to an EDU version, by opening it in an EDU-mode ArchiCAD and then resaving it,
In teamwork mode you need to reshare your EDU project before you sign in.
I'm not sure what i'm suppose to do, how do i reshare before i sign in?? and the file isn't a .edu file anyways, its a .pla file.
tats
Dear djkunalp,
Try to open the training guide file (pla file) when you load Archicad, or from the menu
"File -> Open" then locate and select your pla file.
I hope this will solve your problem
tats
Graphisoft - Product management team
