rotate an object on z axis
is it posible to rotate an object on z axis? it would make my work easier.
p.s. as you can see I'm not an expert
3 Replies 3
TomWaltz
Rotating on the Z axis means to rotate it in plan view.... have you tried the Rotate command? Or did you mean a difference axis?
Tom Waltz
sorry, my fault! I ment to rotate around the x and y axis...
TomWaltz
It depends on the object. Some have parameters for X and Y rotation, some do not.
You can make anything into an object by rotating the 3D window and saving it as an object from that rotation, but it's a really annoying workaround.
Tom Waltz
