rotation problem
hi,
iWve designed kind of a billboard by slab tool.letters has thiknesses on the billboard. now i want to rotate it and stick it on a wall which means i worked on xy plane by slab tool now i want to change that axis as xz axis also rotating that billboard as well. i couldn't find a way to rotate it.please help me
3 Replies 3
Dwight
You'll be making an object.
See:
AC11 reference guide page 232 "Saving 3D models as Objects"
Many users keep a special layer or story in their project to build elements.
Dwight Atkinson
thank you dwight. where can i find reference guide ac11? i have ac10.
Dwight
Are you fooling with me?
I feel that i should warn you that you'll be wasting your time trying to learn Archicad if you lack the insight to transpose backwards to a prior training guide once someone has even supplied the title of the article you need to see.
Guides are accessed through the "Help" menu as with any other software.
Also: You might now understand that when posting a question it is important to publish your software and hardware in your post signature to avoid wasting time since different Archicad versions sometimes have different solutions.
Dwight Atkinson
