SOLVED!
3D ROOFS
bobby bent
I'm having difficulty tucking in a 3D roof when the roof above (sloping in the same direction) blocks out the roof below. Is there a workaround for this?
Windows 10 (Home OS
3.4 GHz i7 Six Core
32 GB SDRAM, NVIDIA Quadro K620
ArchiCAD 24 (USA Full)
1 ACCEPTED SOLUTION
Solution
David Maudlin
Bob:
From your description, it sounds like the upper roof is trimming the lower one. If that is the case a small Connections icon (4 squares inside a larger square) appears when the roof is selected. Clicking on this icon will show the elements of the operation, and allow you to cancel the operation. It might also help to turn on Trimming Bodies in the On-Screen display Options.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
5 REPLIES 5
If you are working in 3D then select all (CTRL+A) and then un-select the roof you want to hide.
Or just select those elements you want to work with.
Then right mouse click and 'Show selection in 3D'.
This will effectively hide what is not selected.
Or in 2D select just the elements you want to work with and then view in 3D.
bobby bent
Thanks Barry, If I eliminate roof above the roof below configures correctly. But when I render I need both roofs to be shown without a gap. What do I do.
Thanks
Bob
Windows 10 (Home OS
3.4 GHz i7 Six Core
Solution
David Maudlin
Bob:
David
bobby bent
Thanks Dave.......that was the problem....problem fixed!
Windows 10 (Home OS
3.4 GHz i7 Six Core
David Maudlin
Bob:
Glad to read it is solved, thanks for posting back.
David
