3D Section
This is probably a dead silly question, but i'm having trouble with the 3d sections in Archicad 10. When i use the marquee tool & press F5, it will only bring up the 3d section for that particular floor. I need complete 3d sections of the building. Are there any settings i need to change to achieve this?
Also, when i save 2d drawings to jpg or pdf, and use them in photoshop, the quality of the line is very bad. What is the best way to to go about moving a drawing to photoshop to create a photo montage?
I had a look through loads of pages of the forum but couldn't find it. I would be very grateful for any help you could give me on this matter as i would need to do both these things asap for my uni hand in! Left to the last minute, ooops!
1 Reply 1
When drawing the Marquee make sure that is it set to the Thick Marquee not the thin one. This will allow you to do the whole building.
When exporting 2D plans try printing it to a PDF then opening in photoshop.
