ā2006-06-10
02:01 AM
ā2023-05-23
05:15 PM
Rubia Torres
ā2006-06-11 09:56 AM
NOELDESIGNS wrote:This is for me very big advantage. I dont need to check every time marquee selection on ground floor.
In AC 10, when I click on a wall (example, could be anything), and click on the 3D button, the entire model shows in 3D, not just the highlighted object, wall, etc.
I can right click on the selection, and choose "Show selection/marque in 3D" and it works.
However, when I close down 3D and highlight something else entirely different, the previous selection shows in 3D again, not what was selected.
Are these bugs or am I using AC 10 incorrectly?
Thanks,
Grant
ā2006-06-11 06:13 PM
Archi wrote:BTW: You don't have to wait for the 3D window to finish drawing. Ctrl+. (control/command + period/full stop) will cancel the process. This will also work in dialogs etc. (It does not work for a task in process such as drawing a wall, nor in endless loops and such where the program is not responding
In this case I had to wait till every part ist built in 3D window.
ā2006-06-12 12:18 PM
If there is no selection then Show Selection in 3D shows the entire model (same as Show All in 3D). After you make a selection (in plan or S/E) and then invoke Show Selection in 3D you are taken (of course) to the 3D window where there is now no selection. Thus invoking the command a second time shows the entire model and the behavior appears like a toggle.But does it? It shows all but doesn't toggle back to the original selection from the floor plan or S/E. It would make more sense to me if we could now toggle between our selection and the entire model.
But on the third try nothing happens because the original selection from the 2D window is not stored. On the other hand, if you now make a selection in the 3D window the Show Selection in 3D command will isolate that selection.Yes! and we can now toggle between that 3D selection and the floor plan or S/E selection, which is very user friendly. I just wish we had that same toggle before our 3D selection!
ā2006-06-12 05:05 PM
ā2006-06-13 12:09 PM
Link wrote:I said it
ā2006-06-13 01:03 PM
A toggle sounds good until you consider the fact that ArchiCAD can maintain a distinct selection set in each open window. If you were in a Show All in 3D state and toggled to Show Selected, which selection set would it use? This does open the question of whether ArchiCAD should change to having single selection set across the entire model.I'd personally like to see it toggle between the selection of the last window open and the entire model. That makes sense to be (but doesn't mean it makes sense to everyone!
