3D perspective
When i go to my 3D Perspective it wont show anything, there is nothing to see, though when i go to 3D Axonometry it shows the view, even if i ring the model an it F5 it just shows it in Axonometry.
I want to import the 3D model into Artlantis but says the model needs to be saved in Perspective, i can save the file but there is no model to see.
anyone else get this problem, and a solution how to fix it.
O btw using ArchiCAD 12.
~~Cheers
13 Replies 13
That didn't work, is there a way to delete the perspective an recreate one from the project map? hoping that it will just fix itself when creating a new one.
I have the same problem i thought that was problem with installation so i reinstalled program but it is same. also have a problem with library and 3d view (also in axonometria) every time when i click on 3d view it shows me window that is missing object but it's not.... and i cant find any solution.. so, if someone has this problem also, and know the solution please help us.
Hmooslechner
Try to switch 3d from openGL to internal engine - if its appearing - then You have a problem with Your graphic-hardware..or driver software..
The thing is its not just my PC, its like unique to the Job file, this happens to a few of our projects where the 3D perspective disappears, but the Axo is still there.
Also how do I switch from openGL to internal engine? << Nevermind found it in View > 3D view Mode > 3D Window Settings
