3D rotating
Is it possible to rotate an object around an axis of choise, rather than just the z-axis?
5 Replies 5
Link
You can view it from any angle in the 3D window, but if you want to rotate the actual element, then you'll need to 'turn to' (get it? ) GDL in one way or another,
Check this post - it may interest you:
http://archicad-talk.graphisoft.com/viewtopic.php?t=5201&highlight=
Link (the latest old veteran).
Dwight
A chief issue with ArchiCAD as it stands....
but if you are seriously intending to twist and rotate, get ArchiForma. This add-on can rotate anything it makes quickly.
Dwight Atkinson
I'm not sure if you are asking about navigation in the 3D window or rotation in Object creation.
Um, ok. But I can still create mesh obejcts in other apps and import them to ArchiCAD and make an object out of them, right? TerraForma sounds like a good option though, I'll look into that. I really need to be able to make custom objects, I think.
woodster: I meant rotating the object, not the view.
Link wrote:
You can view it from any angle in the 3D window, but if you want to rotate the actual element, then you'll need to 'turn to' (get it? ::roll::) GDL in one way or another,
Thank you so much!
Just the answer I was looking for.
Problem solved
