Llian
3D views not showing up
I had no problem last night going back and forth from plan to 3D views and this morning, there are no 3D views….what did I do?
Lilian Seow LEED AP | cSBA | CAPM | PMP
AC 29 USA FULL | Windows 11 Enterprise i5 3.10GHz | Archicad-user since 1994!
3 Replies 3
Try fit in window & then show all layers.
Llian
Thanks. I did show all layers and view extension. No 3D. Only the X, Y and Z coordinates. I had to copy and paste into a new template.
I solved this problem using the marquee tool. Go to the floor plan, draw the marquee tool and press f4 on Mac or f5 on windows. After you enter the 3D mode, also use the "fit to window" mode, then the model should appear.
