3d Window defaults to 'Existing' view
I'm having the problem of the renovation filter changing from 'Planned Status' to 'Existing' almost every time I switch back to the 3D window from the plan (or another window). It's really annoying and wastes about 40 seconds generating the model each time. I've tried to find a pattern but I can't seam to tie it to anything in particular.
Anyone get this issue and figured a way to fix it? Can you set the 3D window to always open (or stay) in the 'Planned Status'?
Thanks
Are you using the View Map to navigate? You may be using views that are set to the Existing reno filter.
If you are not using the renovation features you could delete all but the Planned Status filter.
David Maudlin
This is a known bug, you are not alone. Must use a View to avoid this.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
