3d truss
Is it possible to convert a 3d truss drawing from autocad to archicad?
Another possibility is to draw it wit the coordinats, but i dont know if it is possible, i need some kind of 3d trussmaker.
thank you
kim, student, denmark
5 Replies 5
Ben Odonnell
Kim,
You can import a DWG file, 3D or not, as a GDL object. File--->GDL Objects---->Open object. Then simply change the file type to DWG and import with the correct settings, scale etc.
Cheers.
Ben
Ben O'Donnell
Architect and CTO at BIMobject®
Get your BIM objects from bimobject.com
Djordje
If it is a planar truss, you do have a TrussMaker in ArchiCAD by default. Look under Extras!
The spatial trusses are "a bit" more complicated ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
It is a spatial truss. Am i in trouble then?
I have tried to import my dwg file from autocad, but all i get is a gdl object made of thin lines!!
Them i tried to convert my lines (in autocad) to solid cylinders, but then i could not convert it into a gdl object!!
Is there any other ways to do it?
Kim,student Denmark
Ben Odonnell
You can export it as a *.3DS file from AutoCAD, then import it into ArchiCAD with the 3DS importer.
By default the 3DS importer is not loaded into ArchiCAD.
You will need to go to your tools menu----->Add-Ons manager----> Search for more add-ons-----> then brows to your goodies folder, which can be found in your ArchiCAD folder.
In the goodies folder you will find a folder called 3DStudio in.
After the initial loading of the add-on, ArchiCAD will need to be restarted, you will receive a message after you have loaded it.
Once ArchiCAD starts up again, you will find the 3DS importer under your "Extras" menu.
HTH.
Cheers.
Ben
Ben O'Donnell
Thank You, Thank You, Thank You
It worked, now i have a nice archicad gdl truss and a nice autocad 3-d truss.
best regards. kim
