heathldesign
A 22 very jittery pan
hi there, i have an empty file except for a simple terrain and external drawing as an underlay for tracing, zooming is fine, but panning is really jump and very frustrating. this is a good machine so it really should not behave like this. and i have another big model that, in 3D struggles to orbit. what has happened? it wasn't like this in AC21.
MAC Studio 2022 M1 Max, 32 GB RAM, 10 cores, AC27 5030 Apple Silicon USA Sequoia 15.3. AC 27, 6000 USA
3 Replies 3
Did you checked if there are any elements far apart from each other. It could be either 2d or 3d element? To check, make all layers visible and use "select all" and "zoom to selection" on every floor and 3d space.
Did you tried to select an object you want to edit and use "zoom to selection"?
heathldesign
there isn't anything far away, in 2d or 3d. when i zoom to extents it pans fine, but when i zoom in it's bad.
heathldesign
i lied, it's similar, but not quite as bad.
