rob2218
Cabinet object visibility in elevation is not showing up?
Section thru building.
interior elevation object (cabinet object) is not in section.
countertop is somehow not "visible" in section/elevation view.
neither is bottom toe kick base plate area (in red).
what gives?
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
3 Replies 3
rob2218
here's the section in full.
as you can see...the cabinet countertop portion of the object doesn't
show up in the elevation. Remember cabinet object is "NOT" in section.
i>u
Edgewater, FL!
SOFTWARE VERSION:
rob2218
ISSUE RESOLVED.
see attached JPG explaining what "button" does shut off the "3d edge visibility".
Posting this resolution on the problem I had for all other users who are having the same issue and haven't figured out yet why what causes what....
i>u
Edgewater, FL!
SOFTWARE VERSION:
rob2218 wrote:
ISSUE RESOLVED.
It's stil invisible (in Section View) if countertop is rounded.
Any thoughts what to do?
