Eszter Atlmann's survey
Name game alert: Take our quick survey!
Cabinet object visibility in elevation is not showing up?
rob2218
Section thru building.
interior elevation object (cabinet object) is not in section.
countertop is somehow not "visible" in section/elevation view.
neither is bottom toe kick base plate area (in red).
what gives?
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
rob2218
here's the section in full.
as you can see...the cabinet countertop portion of the object doesn't
show up in the elevation. Remember cabinet object is "NOT" in section.
i>u
Edgewater, FL!
SOFTWARE VERSION:
rob2218
ISSUE RESOLVED.
see attached JPG explaining what "button" does shut off the "3d edge visibility".
Posting this resolution on the problem I had for all other users who are having the same issue and haven't figured out yet why what causes what....
i>u
Edgewater, FL!
SOFTWARE VERSION:
rob2218 wrote:
ISSUE RESOLVED.
It's stil invisible (in Section View) if countertop is rounded.
Any thoughts what to do?
