A Comprehensive CAD/BIM Survey
If you like to fill out surveys, this is new Global CAD/BIM Survey. I guess it is good if the ArchiCAD community is also represented. For me it took about 30 minutes to fill it out. At the end you can give your email address and they will send you the results and findings of the survey in April when the survey is ended:
http://worldcadaccess.typepad.com/blog/2014/03/its-time-for-you-to-fill-out-the-cad-survey.html
0 Replies 0
