A minor Text Tool bug
I found a minor bug in the Text Tool.
When I switch the background fill and offset it, the selection dots do not change their position according to the new size of the rectangle, which makes it difficult to select the letter.
This problem does not appear when the boundary is switched on.
5 Replies 5
Kliment
What hotfix are you on? I am still on 1010 and don't have this problem. I hope they haven't "fixed" it.
It works in swedish 1010 too.
There is definitely something happening to text in the 1183 update. It caused all my text (Arial Narrow) to reduce it's spacing width. I had to go back to 1010 to fix the problem.
I had noticed there were some text anomalies in early builds. Maybe this fix was trying to correct this.
Update to 1183 with extreme caution.
I concur with this as well. I have reverted to the 1010 patch because of some serious issues I was having with PDF output. I would recommend that no one moves past the 1010 patch unless you have good reason. Graphisoft seems to have taken several steps backwards. The closeness between the 1176 patch and 1183 release dates lets you know that there were certainly issues with the 1176 patch and the problems I was having were not corrected by the 1183 patch.
It is OK now with patch 1176!
I am still anxious to get 1183 - perhaps later.
