A minor yet serious bug in AC11?
Has anyone tried the special snap points - between intersection points tool on a curved wall with a couple of linear walls trimmed by the curved one? When i try to use the tool in plan, the index point flashes at some weird point which is not definitely the half point for example between the intersection points of walls! However, if you try it in the 3d window, it works fine. Any comments?
16 Replies 16
No problem with straight walls. The bug occurs with curved walls and only in plan view.
To make it more clear, if you try to find the middle point of the curve between intersection points in the first zone, the snap point flashes on some random point far from your intention, in my case, on the other zone.
Laura Yanoviak
Yes -- I agree. It does not seem to be working as it should.
i am relieved that i was not a complete idiot, as i have been obsessed with this little annoyance for a long time
Laura Yanoviak
burak wrote:
i am relieved that i was not a complete idiot...
That's the beauty of this forum. Or, at least, if you are an idiot, you're not the only one.
no other comments? or is it something that minor not worth commenting on?
Same problem here. Not much to comment on this ... except that I hope it will be fixed in the next hotfix (or maybe in AC 12).
Cheers.
Adrian Tudoreanu
Judit Boros
Graphisoft Alumni
Graphisoft Alumni
Thanks for the report.
We will make sure it’s fixed at the earliest possible opportunity.
Judit Boros
Technical Support Team
Budapest, Hungary
archicadwiki - the ArchiCAD knowledge base
