AC 18 Skylights
While using the "Skylight Domw Circular 18", linked to the correct roof, the skylight also appears in all the lower floors also.
Any way to remedy this?
Thanks in advance for your reply
Win 10 Home Premium - AMD Phenom IIX6 1090T Processor 3.20 GHZ 8.00 GB RAM 64-bit Opp. Sys NVIDIA Quadro 4000 AC 22, MEP
In model view options or in the settings for the skylight
Roger,
My settings are exactly as shown in your picture, however, the problem persists.
Thanks for your trying
I found the solution.
The Floor Plan and Section - under the setting Floor Plan Display I selected the "Projected" option and the problem was solved.
