‎2020-10-23
08:48 AM
‎2023-05-25
04:51 PM
Rubia Torres
‎2020-10-23 10:12 AM
‎2020-10-23 10:30 AM
‎2020-10-23 11:11 AM
atfonit wrote:
The contours just dont react when hovered over and the magic wand tool itself doesn't do anything either when hovering over the contour.
‎2020-10-24 11:21 AM
‎2020-11-08 04:33 AM
‎2020-11-09 03:11 AM
Jennza wrote:
I've found an answer to my magic wand not working: The item (in this case a Spline) needs to be selected first. Then select the mesh tool , shift select mesh, spacebar for wand, then click on Spline again.
Only in this sequence does the magic wand work correctly.
Hope this helps too![]()
