JG
AC 25 mouse issues
I recently started using AC25 on my new MBP M1 Max. I've been a user since AC17, for the last years on a Windows computer.
After working about 20 minutes, something happens with the mouse. I can't pan anymore, I cannot choose between the different types of marquee tools etc. If I scroll, the pan hand appears and I can pan and zoom at the same time. I have to left-click to get out of it.
If I restart the computer, all is fine again for about 20 min, then same thing happens again.
I am using an Evoluent Vertical Mouse C.
Anyone with an idea what might be the problem?
Regards,
Jacob
6 Replies 6
Koji
In the settings panel of your mac, review the security and privacy settings in the accessibility section. be sure to grant accessibility permissions, also input monitoring, if you have a configuration utility for your mouse. perhaps there is the problem, something similar happened to me with my logitech mouse.
Apple MacStudio M2max, Archicad 27 Spanish
Patrick M
Ace
did you import an old work environment into AC25? make sure you rebuild your w/e from scratch with each version (with the exception of keyboard shortcuts). It sounds like a work environment glitch to me... reset to a default out of the box w/e and see if it fixes it.
JG
Thank you for your answers, seems the culprit was USBOverdrive. Installed SteerMouse instead, and that seems to have solved it.
I opened a AC22-file in AC25, but I don't think that was the problem.
JG
Nope, SteerMouse did not solve it. The same problem is still there. After working about 20 minutes, pan function stops and I can only pan while zooming with the scroll wheel.
Same problem when using another mouse, I tried with a wireless Microsoft mouse.
JG
Not getting rid of this problem. Anyone know what might be the problem?
I have to restart the computer to get the mouse to work correctly. Archicad 25 seem to freeze in certain aspects regarding the mouse. What I can click, panning etc.
Minh Nguyen
Dear Jacob,
Thank you very much for the report and I am very sorry for the experience!
Since the mouse you are using is quite a special one, I'm wondering if you have tried with a more simple mouse? When the issue happens, can we use the trackpad to navigate instead of using the mouse?
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
