‎2006-09-20 03:37 AM
‎2006-09-20 10:16 PM
Miki wrote:Miki & Rakela,
Dan.
What was the reason to use ArchiForma here? Just ease of work? I don't see a real need for it. Nice design BTW.
‎2006-09-25 02:21 PM
There are many reasons why I use Archiforma. the best one to describe with the attached image is the ability to ceate an element that can curve in two directions...see the image for description.
‎2006-09-25 02:25 PM
djlandreneau wrote:Do try to find some offices working with AC and some with Revit and interview them. Evaluate learning curve, productivity, communication to other software, how it is to own...and you have a no brainer...called Archicad. It's not interesting at all what a software can do. What's interesting is what a user can do with the software...period.
All,
I know that this topic has been discussed in the past, however, what I am trying to decide is whether to move my office to ArchiCAD or Revit.
Currently we are using SketchUp for the design process and Autocad LT for the documentation portion of our projects.
We have decided that using software applications like ArchiCAD will yield efficiencies in our organization on a number of levels; however, we are trying to decide between AC and Revit.
I have obtained trial copies of both and have gone through tutorials and sample projects. What I am looking for is opinions from this forum as to why AC is better than Revit - what can't Revit do that AC can?
Incidentally, we specialize in residential and light commercial work with a modern emphasis.
Thanks in advance for everyone's assistance,
DJ Landreneau
‎2006-09-25 04:52 PM
‎2006-09-25 07:54 PM
freya wrote:What kind of design?
Advise what program need beginning designer
‎2006-09-26 04:17 PM
Rakela wrote:Rakela,
Dan, would you mind, if u have a chance, sharing your procedure to create
a double curve profile using archiforma ??
‎2006-09-26 05:23 PM
‎2006-10-02 06:02 PM
‎2006-10-02 06:41 PM
jdk wrote:As I recall about 14 years ago ArchiCAD offered a competitive upgrade from AutoCAD for $1500. I don't know how successful it was then but perhaps now would be a good time to try it again.
If you have an old autocad, you can upgrade for under 1500$ and get both Revit-9 and a full autocad 2007.
‎2006-10-02 07:36 PM
