AC on multiCPU PCs??
Hi all,
this is my first post and I would like to know if there will be an ACx version that will run and "USE" two or more CPUs on a windows Workstations.
I've very heavy models to work on... and so...multi CPU AC?
Thank you
PWD
4 Replies 4
I think we never heard any word from GS about dual processor support... there have already been many posts about this subject on ac-talk (email version).
You can search on : http://www.escribe.com/software/archicadtalk/search.html?query=dual+processor
I don't know the answer, and agree that it is something that we must see in the future.
I was just wondering about a possibility yesterday for using a second CPU to more advantage since I finally tried Teamwork. I wonder if for a 'heavy' model as you have there might not be an advantage to using Teamwork with two ArchiCAD sessions open - with one session assigned sections/elevations.
The largest house model that I have is plenty fast on my 3GHz processor, so I can't really test the efficacy of this idea. But, if you have a huge model that takes a considerable amount of time from which to generate a live sun-shadowed, hatched elevation for example - then generating the elevation in one Teamwork session (and CPU) while you're working on the model in the floorplan/detail session (and CPU) might be of some use as a crude workaround? (Layer assignments between the two sessions is a big hassle for productive work since you can't move elements in the elevations/sections if the layers that those elements are one are assigned to the floorplan session.)
Just a weird thought.
Karl
Excellent idea, but wouldn't it be more simple to use specific display option : one to annotate the section in "raw" mode without any shadows and hatching and one for "presentation" elevation, only used from plotmaker -> if you link directly to these views, PM launches a second AC session, and this one will use the 2nd processor...
It would be a good start without having to deal with teamwork workspace management...
Does anyone know if a thread / entire process can be assigned to a specific processor or do we have to rely on the OS to achieve this ?
Djordje
This is how I see it, besides TeamWorking; I usually do have both ArchiCAD (at least one ) and PlotMaker open; at the update time, the background ArchiCAD jumps in - so two processors are needed! With a couple of gigalons of RAM of course ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
