AC11 Little improvements......
Wanted to start a list of AC11 Little improvements......which are not announced:
First Selection outline now is shown in dots
Second Selection outline is shown in Dot Dash Dot
Nice, yet still short cut C for changing of the method is still not implemented, must be very hard to code it in!
Joseph
143 REPLIES 143
Rafal SLEK
"Intersect" command works for Beams
Best
Rafał
//Archicad since 4.1 version
//MacBook Pro Retina 2019/2.4 GHz/Intel Core i9/32GB RAM/Radeon Pro 5500M 4GB/macOS 13.6
//Razer Intel i9/2.5GHz/32GB/Nvidia RTX 3080/Windows 11 Pro
//ArchiCAD 28/Twinmotion 2024
Interactive schedule works more acurate - eg. when scheduleing areas it used to round the values twice the zones values and the total value separately - so the total was not equal to the sum of the listed zone areas - and it is now fixed!!!
The window and door markers can export to dwg on separate layers - very usefull improvement!!!
Best Regards,
Piotr
Best Regards,
Piotr
Door and window list is not working good with cadimage dwbuilder.
When i start door list i get everything fine but i cant get 3d front or back view and
in window list i cant get 2d symbol but 3d front view is working fine ?????
Strange thing,dont u think so ???
And ofcourse, when i insert door or window from AC11 everything works fine. So this thing is probably connected with cadimage dwbuilder for AC11. What a stupid bug !
TomWaltz
I think that's why CADImage provides their own schedules. I don't expect the Archicad scheduler to work with something from a 3rd party add-on.
Tom Waltz
Everything was working super with AC10, this is now, but i will try with their and offcourse, i will infor u here what results are !
Link
How about we stay on topic - it's such a good one.
A little AC11 improvement is the Options> Work Environment> Enable all informational messages... that, apart from bringing up one of ArchiCAD's quirkiest messages, will enable all information dialogs that have a checkbox at the bottom left corner. Note, this does not apply to the FindOutMore dialog which is a separate application (stored in the ArchiCAD folder).
Link.
Been using Version XI now for days. Everything works great. Have had no slow downs on Win XP. The new trace function is marvelous.
Mark Hendricks
mark-
just installed it today... trying to work some library kinks out.... did you transfer a project from an earlier version (i was using using 10).... any problems with composite walls.... elevation/section markers..... ect?
if you have any words of wisdom to make this transfer... i'd love to hear anything
k
Kbot,
I did not work on an older plan with XI, I started two new projects only. I am staying with version 10 when working on older projects to avoid any problems. Sorry I can't be of more help.
Mark Hendricks
