2007-06-20 12:34 AM
2007-06-25 11:59 PM
Kbot373 wrote:I have moved one project from 10 to 11 and found a slight quirk in the section/elevation transfer. I had one section that used an elevation marker since the two end markers were cut off in the layout of the plan. When translated to 11 it is an Elevation and you can't seem to change it to a Section (Section marker doesn't seem to be available under the elevation marker sub-menu). So check all of your markers in 10 before you move over. Also make sure you download the AC10 Subset library from the Goodies web page (under the help menu). The library transfer has been surprisingly smooth.
mark-
just installed it today... trying to work some library kinks out.... did you transfer a project from an earlier version (i was using using 10).... any problems with composite walls.... elevation/section markers..... ect?
if you have any words of wisdom to make this transfer... i'd love to hear anything
k
2007-06-26 12:03 AM
aahatimo wrote:I know what you mean. They can come up with gorpy new artwork for the splash screen, why can't they come up with a gorpy new icon?
one little improvement gs did not do was come up with a v11 desktop icon. to me it looks exactly like v10 icon. do i need my eyes checked??!! did i really get v11? sometimes it is the 'little' things.
2007-06-26 02:17 AM
aahatimo wrote:You may know this already but you can right mouse click the Icon and go to Properties and the then Select the Change Icon.
2007-06-26 03:29 AM
2007-06-26 04:42 AM
2007-06-26 05:26 AM
2007-06-26 05:34 AM
aahatimo wrote:Sorry, no screen shots (sadly i'm stuck on windows), but do this:
stuart, great v 11 icon (maybe x.99++).
jay, i headed to the mac side a few years back. i have not figured out how to do the 'change icon' thing on a mac. really i am not sure why i would need to.
aahatimo wrote:Neither am I - is a new icon necessary? Until V10 we had the same 3 pencils for ever...
2007-06-26 05:59 AM
2007-06-26 11:07 AM
aahatimo wrote:Select the file/app/whatever in finder. Command I (info). Click on the icon then command V (will paste what is in the clipboard into the icon view).
2007-06-26 01:36 PM
