AC11 Little improvements......
Wanted to start a list of AC11 Little improvements......which are not announced:
First Selection outline now is shown in dots
Second Selection outline is shown in Dot Dash Dot
Nice, yet still short cut C for changing of the method is still not implemented, must be very hard to code it in!
Joseph
143 REPLIES 143
i can f@@@@@@ believe that a whole new edition ARCHICAD 11, have almost the SAME library(ICF) with the old archicad 10 and the older archicad 9 version
This is mean that graphisoft,or nementchek wrigt now, expect from as to use additional gdl objects and not the included in the library as sould it be
ooops, sorry for the double posting, i did it by mistake
TomWaltz
There's actually a number of new objects in the library. Were you expecting a major rewrite of it?
Tom Waltz
If the furnitures layout is enough for you,ok
But, in the 2007, the default library objects that archicad 11 give, seems like cartoon in most users
Rakela Raul
have u ever seen better libs than Archicad libs? and if you have, which software ? thanks
MACBKPro /32GiG / 240SSD
AC V6 to V18 - RVT V11 to V16
SeaGeoff
Ace
Don't know if it's been mentioned but in AC11 TeamWork has been fixed so that you may now add any viewpoint type to a story that is owned by someone else. In AC10 and earlier you can do his with the S/E tool but if you try with the Detail tool you get an error. Very annoying since it forces a change of workspace by two teamates to create and transfer ownership of even a single detail, repeat each time you realize you need another one. Now it works for Details, Worksheets and IEs. For those working in TW this is a not-so-little improvement that justifies the upgrade price all by itself.
Regards,
Geoff Briggs
I & I Design, Seattle, USA
AC7-28, M1 Mac, OS 15.x
Graphisoft Insider's Panel, Beta Tester
fhedberg
A quick question from someone who doesn't have AC11...yet..
I was just wondering if the drawing schedule in AC11 differentiates between subsets..?? (eg. Can the drawing schedule list the subset heading and separate the different ones?)
I know there are work arounds (setting up separate drawing schedules with different criterias), but shouldn't this be a standard option in the schedule it self or am I asking for to much? Have I missed something?
W11 Home | ArchiCAD 27 3001 AUS FULL
Link
Unfortunately not. We wished and we asked and we pleaded, but it didn't make it.
Hopefully next version!
Link.
In version 11 I am my "Preview Options" for objets does not work. Anyone Else?
Thanks,
Mark Hendricks
Thanks,
Mark Hendricks
Wow, It's been a long day. Let me rewrite that:
In Version11 my "Preview Options" for objects does not work.
Anyone Else?
Thanks,
Mark Hendricks
