‎2007-06-20 12:34 AM
‎2007-06-29 08:18 PM
‎2007-06-30 12:05 AM
NeckoFromSarajevo wrote:If you use Solid Operations instead of the Trim to Roof, then Hotlink your model into another project, the Solid Operations will get lost! I've run into this with AC 10 and now 11. Walls that I used an SO to fit under a roof suddenly protrude through the roof when hotlinked, but not in the original model. Using Trim to Roof has been the only fix I could find, though I like using SO much better.
Trim to roof should be deleted /solid operations are future
‎2007-06-30 01:58 AM
‎2007-06-30 02:49 AM
genarch wrote:When Hotlinking the SEO's will only carry over to the host file if both Target and Operators are on the same story.
‎2007-06-30 06:00 AM
owen wrote:I think you'll find it works fine in AC11.
GS really should do something to fix this. SEO's need to be maintained through Hotlinks regardless of the stories that Operator and Target are on.
‎2007-06-30 05:45 PM
‎2007-07-02 03:27 AM
Link wrote:owen wrote:I think you'll find it works fine in AC11.
GS really should do something to fix this. SEO's need to be maintained through Hotlinks regardless of the stories that Operator and Target are on.![]()
Link.
‎2007-07-02 04:13 AM
"vfrontiers" wrote:
Could someone verify that the D2 Segmented will NOT accept CUSTOM DOOR PANELS? The feature is there, but if you choose CUSTOM, the place to type in the panel name disappears. If I type it in when "custom" is not selected then select custom, it does not find the panel (presumably, the typed in name goes away)...
Anyway, I just want to verify...
I am experiencing the same problem...
‎2007-07-02 05:21 PM
Link wrote:I'm using AC11!!! Still have the SEO problem, though.
I think you'll find it works fine in AC11.![]()
‎2007-07-02 07:40 PM
