AC14 quick layer selection problem
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2011-03-07
02:57 AM
‎2023-05-26
02:33 PM
Rubia Torres
in AC13 we were able to quickly select a layer in the 'layer settings' window by typing the first couple of characters or numbers of a layers name.
in AC14 however, if you do start typing it will jump straight to a layers extension field and insert the typed characters, replacing any existing characters.
is this a new feature, new setting (that can be changed) or a bug?
ds.
Design Technology Managers.
All  on macOS | since AC 6
Archicad Framework > Smart Template 27
Smart Tree, Transmittal and Universal Label and other smart GDL Objects
By Architects for Architects.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-03-07 11:32 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-03-08 12:37 AM
Link.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-03-08 03:22 AM
Link wrote:I don't think that's it. I tried typing in the list and after jumping to the first entry that started with the first letter I typed, it entered the extension field and put any additional characters there. (My layers were not sorted by extension.)
Are your layers sorted by extension? If so, perhaps sorting them by name may fix it?
Link.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-03-08 03:47 AM
If you do select a layer with the mouse then if you select on the name it will just start amending the name field.
If you happen to click on the name for the "Archicad layer" (which you can't change) then it will jump to the layer beginning with your first letter typed and will then amend the name of that layer with the rest of the characters you type.
The same happens if you click in the file extension field.
If you do manually select a layer with you mouse try to do it in the small space between the layer name and extention.
This will not enter the cursor into the text field and you will be able to type as many characters as you need.
Basically keep the cursor away from any of the text fields.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-03-08 04:22 AM
Barry wrote:The same behavior occurs in AC11, so maybe it hasn't been changed in intermediate versions, unless it was changed in 13, then back for 14 (which is always possible - didn't they do something like that with MVO's?)
I have discovered it works fine when you first open the layer dialogue so long as you dont manually select any of the layers with the mouse.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-03-08 05:16 AM
Works fine on AC14 Win here. Maybe it's a Mac thing?
Link.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-03-14 05:59 PM
VP, Customer Success, Graphisoft
