Hi Conrado,
Works fine for me. I assume the MEP 14 library is a typo for MEP 15 and that you downloaded the MEP Modeler from the GS web site and installed it, rather than importing the MEP work environment from 14? (The MEP 14 library does seem to work interchangeably with the MEP 15 library - automatic reassignment of placed elements to either library.)
Just in case some customization happened - is the 'show on stories' value for the MEP tools that you clicked set to "All relevent stories"?
Is it possible the the (new) renovation status for these elements is not set to the default ('existing', 'show on all relevant filters'?
One of the forum moderators
AC 27 USA and earlier • macOS Ventura 13.6.8, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
