AC16 Bug - Tool bar selection problem
I've created custom tool bars but the right click context menu that's used to select or unselect the visible tool bars is unable to display tool bars whose names alphabetically sort themselves to the bottom of the list in the customize toolbar tab in the Work Environment dialog when the tool bar is visible. This makes it impossible to turn off tool bars that are currently visible without having to rename them to something that sorts the name to the top of the alphabetic sorting.
I tried to follow your instructions but this works fine for me.
I created the ZZZ Toolbar and it is at the bottom of the list and I can select it all right.
If the list gets too long there should be a "More Toolbars" option you can select.
