AC19 zone stamp issues
Are there no other options for zone stamp in AC 19? I prefer to use MasterScript Total Zone, but the "load other zone stamp" option appears to be missing in 19.
If I'm stuck with the GS zone stamp, how can I get it to list the floor material for each zone? I see it is an option in the zone settings, but where does it read this parameter from? Does it pick up the surface of the topmost slab? Or must I fill this in manually for each zone (which kind of kills the BIM aspect)?
1 REPLY 1
David Maudlin
You can change the Zone Stamp in Zone Categories..., you should find it with the other Attributes (Surfaces..., Line Types..., etc.).
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
