thompsonmp wrote:
So you can update the detail/worksheet if there are any amendments?
Yes, when you open the detail you can right mouse click and choose "Rebuild from source view"
Or you can right click on the detail in the Navigator.
Just remember if you adjust any of the 'linked' lines and fills in your detail or you adjust your model then they will all 'linked' lines will adjust to match the model when you rebuild from source view.
I usually take a copy of the generated detail and move it to the side - so effectively there are 2 details in the view.
One is live and the copy is not.
I annotate that copy so that it never updates on rebuild but I can see the changes on the original detail and can copy to the duplicate again if need be.
Lenovo Thinkpad -  i7-1270P   2.20 GHz, 32GB RAM, Nvidia T550, Windows 11
