AC22 Is there a way to check non straight walls, lines, polylines????
Hi All, do you guys know if theres a way to check lines or walls that a off by less than 1 of a degree? i am currently working on a project that was setup with an angle instead of rotating the model so North Point is rotated. currently i have been drawing a big rectangle fill and place them right to the wall or line and adjusting them 1by1 from there. i would think archicad would be able to list out an untrue model, wouldnt it?reverse phone lookupnba reddit
Eduardo Rolon
here you go
https://bim6x.com/blog/fixing-untrue-models
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
